disable access-list refresh blackhole
Description
Disables blackholing of packets during ACL refresh.
Syntax Description
Default
The feature is enabled.
Usage Guidelines
When access control lists (ACLs) are refreshed, this feature provides that any packets arriving during the refresh will be blackholed.
If you disable this feature, the ACLs will be refreshed as described in the refresh policy command.
To enable this feature, use the following command:
enable access-list refresh blackhole
The following command disables dropping of packets during an ACL refresh:
This command was first available in ExtremeXOS 11.0.
Platform Availability
